hello I’m facing this error in connecting the jetpack XML-RPC is not responding correctly ( 520 ) It looks like XML-RPC is not responding correctly. Please make sure XML-RPC is turned on for your site and is set up to respond to all content types. You can test this yourself by running the following command from the command line: curl -A ‘Jetpack by WordPress.com’ -d ‘demo.sayHello’ https://worldnewsnow.xyz/xmlrpc.php The answer should be: <?xml version=1.0 encoding=UTF-8??>
Hello! After some discussion, they say to contact your hosting provider and please help me
#> @Ahmad435 said: #> hello I’m facing this error in connecting the jetpack #> #> XML-RPC is not responding correctly ( 520 ) #> It looks like XML-RPC is not responding correctly. Please make sure XML-RPC is #turned on for your site and is set up to respond to all content types. You can test this #yourself by running the following command from the command line: #> #> curl -A ‘Jetpack by WordPress.com’ -d ‘demo.sayHello’ #https://worldnewsnow.xyz/xmlrpc.php #> The answer should be: #> #> <?xml version=1.0 encoding=UTF-8??>
#> #> #> #> #> Hello!#> #> #> #> #> #> After some discussion, they say to contact your hosting provider and please help me #>
