Plugin woocommerce installation is not getting completed
I have tried to use Cosmetic store plugin but woocommerce is not getting installed. It keeps on in installing status since more than 45 min Please guide the path forward for the same Regards Anoop
You can uninstall and remove the current woocomcernce installation and then try to download the plugin from woocommerce plugin website and upload it via ftp ( eg: Filezilla) and then try to install.
