hello I can not access the control panel because it shows this problem Because this form is being submitted using a connection that�s not secure, your information will be visible to others.
There should be a Continue Anyway button; hitting that will allow you to proceed. If you’re uncertain, you can login manually to the panel by visiting https://cpanel.liveblog365.com/ and entering the username and password that are show in the FTP section of your client area.
