Hi. I created a brand new account under the ezyro.com domain and tried to log in to the FTP server for the first time. But it didn’t work: I got error 530 Login authentication failed. My username is the one provided in the client area (ezyro_XXXXXXXX) and my password is correct. I changed my password and got the same result. I created another account under the unaux.com domain and still couldn’t login. I have tried with three different FTP clients.
> @JoseFrancisco said: > Hi. I created a brand new account under the ezyro.com domain and tried to log in to the FTP server for the first time. But it didn’t work: I got error 530 Login authentication failed. My username is the one provided in the client area (ezyro_XXXXXXXX) and my password is correct. > > I changed my password and got the same result. I created another account under the unaux.com domain and still couldn’t login. I have tried with three different FTP clients. What FTP client are you using? The one I use is Filezilla, and it works just fine.
After creating new account, you need to login to control panel at-least once for FTP client to work properly.
Thank your for your replies. @TheCrafters: My primary FTP client is the standard command-line ftp command. I also tried to connect to FTP with macOS finder and Firefox, to no avail. @Admin: I did. I even closed the session and reopened it again. @badbot: The IP and username I have been trying with are like those you point. I’m giving up. Thank you again for your support.
> @JoseFrancisco said: > Thank your for your replies. > > @TheCrafters: My primary FTP client is the standard command-line ftp command. I also tried to connect to FTP with macOS finder and Firefox, to no avail. > > @Admin: I did. I even closed the session and reopened it again. > > @badbot: The IP and username I have been trying with are like those you point. > > I’m giving up. Thank you again for your support. You know there is also the Online FTP you could try.
