My websites are not opening
Hi Profreehost team, Please solve my issue my websites are not opening.
Hello Thanks for you
same as me… i change my dns to here profreehost. it was working a while when i install wordpress to my area. it looks fine but now sonerya. com dosent works dosent open at opera… becuse its warn as ERR_SSL_PROTOCOL_ERROR profreehosting cetfificed dosent work its like not trustable server… i changed my ssl and delete cookies shutdown antivirus program i treid almost all ways from help pages and websites by google search. this is the last reason mean profreehosting servers not legal trustable it looks… how can i open my website … yes its may be free but if i can never use and open my site why i move my domain name to here SSL Report: sonerya.com (185.27.134.215) Assessed on: Fri, 08 Sep 2023 15:07:34 UTC | Hide | Clear cacheScan Another » Assessment failed: Failed to communicate with the secure server Known Problems There are some errors that we cannot fix properly in the current version. They will be addressed in the next generation version, which is currently being developed. No secure protocols supported - if you get this message, but you know that the site supports SSL, wait until the cache expires on its own, then try again, making sure the hostname you enter uses the www prefix (e.g., www.ssllabs.com, not just ssllabs.com). no more data allowed for version 1 certificate - the certificate is invalid; it is declared as version 1, but uses extensions, which were introduced in version 3. Browsers might ignore this problem, but our parser is strict and refuses to proceed. We’ll try to find a different parser to avoid this problem. Failed to obtain certificate and Internal Error - errors of this type will often be reported for servers that use connection rate limits or block connections in response to unusual traffic. Problems of this type are very difficult to diagnose. If you have access to the server being tested, before reporting a problem to us, please check that there is no rate limiting or IDS in place. NetScaler issues - some NetScaler versions appear to reject SSL handshakes that do not include certain suites or handshakes that use a few suites. If the test is failing and there is a NetScaler load balancer in place, that’s most likely the reason. Unexpected failure - our tests are designed to fail when unusual results are observed. This usually happens when there are multiple TLS servers behind the same IP address. In such cases we can’t provide accurate results, which is why we fail. Common Error Messages Connect timed out - server did not respond to our connection request, sometimes before we are dynamically blocked when our tests are detected No route to host - unable to reach the server Unable to connect to server - failed to connect to the server, it usually happens due to firewall restrictions Connection reset - we got disconnected from the server Unrecognized SSL message, plaintext connection? - the server responded with plain-text HTTP on HTTPS port Received fatal alert: handshake_failure - this is either a faulty SSL server or some other server listening on port 443; if the SSL version of the web site works in your browser, please report this issue to us Failed to communicate with the secure server - No secure protocol supported. Possibly this server only supports a draft version of TLS 1.3
