So heres the part of the code that gives me the error: <?php include(path.php);
include(ROOT_PATH . /controllers/topics.php);
$posts = array();
$postsTitle = ‘Recent Title’;
$posts = getPublishedPosts();
$trendingPosts = getPublishedPosts();
if (isset($_GET['t_id'])) {
$posts = getPostsByTopic($_GET['t_id']);
$topicName = selectOne('topics', ['id' =?>
$_GET[‘t_id’]]); $postsTitle = Search results for posts under ’ . $topicName[‘name’] . ’ topic; else if (isset($_POST[‘search-keyword’])) { $postsTitle = Search results for ’ . $_POST[‘search-keyword’] . '; $posts = searchPosts($_POST[‘search-keyword’]); else { $posts = getPublishedPosts(); ?> i get this error: Fatal error: Uncaught Error: Call to a member function bind_param() on bool in /home/vol14_8/unaux.com/unaux_26832677/htdocs/database/db.php:20 Stack trace: #0 /home/vol14_8/unaux.com/unaux_26832677/htdocs/database/db.php(154): executeQuery(‘SELECT p.*, u.u…’, Array) #1 /home/vol14_8/unaux.com/unaux_26832677/htdocs/index.php(6): getPublishedPosts() #2 {main thrown in /home/vol14_8/unaux.com/unaux_26832677/htdocs/database/db.php on line 20 dp.php file: <?php session_start();
require(‘connect.php’);
function dd($value) // to be deleted
echo <pre?>
, print_r($value, true), ; die(); function executeQuery($sql, $data) { global $conn; $stmt = $conn->prepare($sql); $values = array_values($data); $types = str_repeat(‘s’, count($values)); $stmt->bind_param($types, …$values); $stmt->execute(); return $stmt; function selectAll($table, $conditions = ) { global $conn; $sql = SELECT * FROM $table; if (empty($conditions)) { $stmt = $conn->prepare($sql); $stmt->execute(); $records = $stmt->get_result()->fetch_all(MYSQLI_ASSOC); return $records; else { $i = 0; foreach ($conditions as $key => $value) { if ($i === 0) { $sql = $sql . WHERE $key=?; else { $sql = $sql . AND $key=?; $i++; $stmt = executeQuery($sql, $conditions); $records = $stmt->get_result()->fetch_all(MYSQLI_ASSOC); return $records; function selectOne($table, $conditions) { global $conn; $sql = SELECT * FROM $table; $i = 0; foreach ($conditions as $key => $value) { if ($i === 0) { $sql = $sql . WHERE $key=?; else { $sql = $sql . AND $key=?; $i++; $sql = $sql . LIMIT 1; $stmt = executeQuery($sql, $conditions); $records = $stmt->get_result()->fetch_assoc(); return $records; function create($table, $data) { global $conn; // $sql = INSERT INTO users SET username=?, admin=?, email=?, password=? $sql = INSERT INTO $table SET ; $i = 0; foreach ($data as $key => $value) { if ($i === 0) { $sql = $sql . $key=?; else { $sql = $sql . , $key=?; $i++; $stmt = executeQuery($sql, $data); $id = $stmt->insert_id; return $id; function update($table, $id, $data) { global $conn; // $sql = UPDATE users SET username=?, admin=?, email=?, password=? WHERE id=? $sql = UPDATE $table SET ; $i = 0; foreach ($data as $key => $value) { if ($i === 0) { $sql = $sql . $key=?; else { $sql = $sql . , $key=?; $i++; $sql = $sql . WHERE id=?; $data[‘id’] = $id; $stmt = executeQuery($sql, $data); return $stmt->affected_rows; function delete($table, $id) { global $conn; // $sql = DELETE FROM users WHERE id=? $sql = DELETE FROM $table WHERE id=?; $stmt = executeQuery($sql, [‘id’ => $id]); return $stmt->affected_rows; function unBan($id) { global $conn; // $sql = DELETE FROM users WHERE id=? $sql = DELETE FROM banned WHERE user_id=?; $stmt = executeQuery($sql, [‘user_id’ => $id]); return $stmt->affected_rows; //$id = delete(‘users’, 11); //dd($id); function getPublishedPosts(){ global $conn; // SELECT * FROM posts WHERE published=1 $sql = SELECT p., u.username FROM posts AS P JOIN users AS u ON p.user_id=u.id WHERE p.published=?; $stmt = executeQuery($sql, [‘published’ => 1]); $records = $stmt->get_result()->fetch_all(MYSQLI_ASSOC); return $records; function searchPosts($keyword){ global $conn; $match = ‘%’ . $keyword . ‘%’; // SELECT * FROM posts WHERE published=1 $sql = SELECT p., u.username FROM posts AS P JOIN users AS u ON p.user_id=u.id WHERE p.published=? AND p.title LIKE ? OR p.body LIKE ?; $stmt = executeQuery($sql, [‘published’ => 1, ‘title’ => $match, ‘body’ => $match]); $records = $stmt->get_result()->fetch_all(MYSQLI_ASSOC); return $records; function getPostsByTopic($topic_id){ global $conn; // SELECT * FROM posts WHERE published=1 $sql = SELECT p.*, u.username FROM posts AS P JOIN users AS u ON p.user_id=u.id WHERE p.published=? AND topic_id=?; $stmt = executeQuery($sql, [‘published’ => 1, ‘topic_id’ => $topic_id]); $records = $stmt->get_result()->fetch_all(MYSQLI_ASSOC); return $records; someone help?
