Hi. Can you please help? How come I can not do a simple default install of phpBB3? It fails with this error below at the bottom of this post when the default installer is trying to create database tables. I have successfully installed phpBB3 many many times before on other hosts. I already first created a database before running the default phpBB3 installer General Error:SQL ERROR [ mysqli ]User lblog_33952309 already has more than ‘max_user_connections’ active connections [1203] in file /home/vol19_1/liveblog365.com/lblog_33952309/htdocs/phpBB3/phpbb/db/driver/driver.php on line 1023
Here is an attached image screenshot showing the actual error regarding max_user_connections Edited: I attached an image url to this post but I guess this forum doesn’t allow me to post images?
