delet all my projects
Hello support i want you to delete my projects bcs i want to start fro 0 i get problems bcs i didnt upload files good
You should be able to remove all domains manually and then close the accounts, after about 90 days they should get deleted. I’d recommend just clearing out the files though, if that’s the issue, simply delete the files in your htdocs folder and upload them again.
I also facing the same problem thanks for sharing the information
